I have a 78 cutlass with a 305 and a 200 3spd. I have a th350 to put in but will the drive shaft need to be shorter or longer? :?:
I second that! mrapii is right. It will be the same lenght. The only mod you'll have to do is replace the Detent cable, or "kickdown" the TH-200 have a bigger end on them.mrapii said:It will swap right in, TH200 and TH350 are the same lenght.
ss4ever said:That all depends on the size of the tailshaft, if it is a short tailshaft then it will bolt right in.
Randy
mrapii said:You evidently have a THM2004R trans and not a THM200C. Any driveshaft from a G-Body (except El Camino) that was originally equipped with a THM350, THM350C, THM200 or THM250 will be the proper lenght driveshaft. Any G Body older than 1984 will have one of those automatic trans and even newer models are likely to have one.
