Drop in Aluminum Radiator Under $300?
MrSony
6,868
6,848
Des Moines, Iowa
Anyone got a part number for an all aluminum radiator that fits in the factory rubber saddles? Looked around and didn't get a clear answer. Any help is appreciated. I'm using a cutlass top plate and shroud if it matters. Hose locations in standard positions. Preferably under $300 bucks. Thanks.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,996
Socialist NY
Did you reach out the the forum sponsor Cold Case?
I know if you call them they will give you a better deal.
MrSony
6,868
6,848
Des Moines, Iowa
MrSony
6,868
6,848
Des Moines, Iowa
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,229
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
U have to CALLLLLLLLLLLLLLL THEMMMMMMMMMMMMMM
My friend paid ALOT less when he called and told him he was from the site
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
What is big rush to get a rad. 220 isn't overheating and with the cold winter you'll be ok for months. Plus you can take the time to find out what is causing the problem if there is one.
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
Will spend 300 on radiator, wont spend 15 on infrared thermometer
:rofl::rofl::rofl::rofl::rofl:
Reactions: 4 users
MrSony
6,868
6,848
Des Moines, Iowa
There's really nothing else I can think of. And I'm not gonna buy one this year, maybe in a month or two. Regardless, I'm gonna get a new rad eventually. That dinky thing arrived bent, and was frozen solid once. I'm surprised it still works. And holds pressure.
Said I was gonna pick one up friday foo...
MrSony
6,868
6,848
Des Moines, Iowa
There is a problem, that much I do know. All the vacuum lines are hooked up, everything on the HVAC side works as it should. The only thing that isn't "new" in the entire cooling system is the radiator itself. Its a few years old, and as mentioned above has seen some sh*t.
