EFE Valve
Tomeal
919
1,633
Clyde,pa
I'm going through the exhaust parts I've accumulated from my parts and it seems I don't have an EFE Valve.
For now I want to run stock exhaust cause one of my parts cars had mostly new exhaust.
So I need to fill that gap where the efe valve goes. I may try some yards to see what they have. I not concerned for it to work, just needs to be open.
Or if anyone else has an alternate solution, I'm open to ideas!
Tomeal
919
1,633
Clyde,pa
20,397
Tomeal
919
1,633
Clyde,pa
I don't think that is the correct one, I think the ones we use only use 2 studs
Your right, there is only two holes. Thanks didn't catch that.
Danser's on 22 in Blairsvill might have one since they had some G's there last time I was there.
I may try them today.
These two hole ones are kinda hard to find online. Found one for $40, but I kinda question the site!
9,194
15,446
There might be a later 2/3 stud set up that works with both the 3 stud truck & 2 stud car manifolds. I'm thinking I have one for my 3 stud set that is like that. I'll have to try to get in the garage to see. This came to me after reading the newer postings.
10,569
14,312
They are discontinued and now very expensive when you do find one. Best bet is a junkyard or Fleabay. I have used broken ones just to get the housing and then filled the shaft hole shut. One side is flat that goes against the flat exhaust manifold. The other side is beveled for the head pipe to seat against. The eliminator spacer is actually a pretty good fix and $40 is not that terrible a price if it gets you a leak free exhaust seal.
