The tank without the filler tube is the same number so I am guessing the only difference between the GM306C for the Monte and the GM307C for the GN is the filler tube.
So I am wondering is it just an issue with the Monte one.
IIRC they didn't have a Monte Carlo FI tank with the fill neck available when I bought mine about five years ago so I used the Buick tanks. When I replaced the fill neck I found one from a V6 FI Monte Carlo in a bone yard and was able to cut it out with a cold chisel. I tack welded the neck to the new tank then soldered it in to seal it. Most radiator shops can solder the neck in if your tank is new.
