El Jefe is getting an El Esse!!
Kratos
205
328
Central Pa
Put the recent clamshells on. Lowered the engine , but I couldnt clear the headers. Moved the mounts just a little bit forward, Massaged the firewall and it's sitting in there with good header clearance. BUT.... I put the truck pan back on, I still have about 6" ground clearance, and since this is a "track only car, I think I will be OK
Big Weekend ahead!!! New .600 springs, , 300-132 manifold, MSD Box, Sloppy copy cam, (228/230 duration @ .050” with .585”/.585” valve lift and 112 degree lobe separation angle)
Maybe we will get fired this weekend, but I doubt it Will post up pics on Sunday with more narrative
5,711
12,224
A Tahoe/SUV pan will give you an additional 4”.
Kratos
205
328
Central Pa
Little bit of progress today. Comp Cams spring compressor worked very well changing the springs then I swapped out the cam for the sloppy 2
Kratos
205
328
Central Pa
Today wasn’t a hard day. Just cleaned up the coil brackets and swapped out the Fi intake for a carbureted manifold
