to have the fans shut down when you shut down the car you have to have the power to the fans on a switched cucuit meaning the power will come on only when the car is running or the key is in run position.
You can use a time delay relay from a 94-98 Dodge Ram to give you 90 or so seconds of run time after the ignition is turned off.gotcha, mine are controlled by sending unit and relays. Looking for a timer
Its funny you would say that bc my father just siad the same thingYou might want to consider wiring it for run only. I had mine set up like that for a while, and it was annoying having the fans come on any time i turned the key to accessory to listen to the radio.
With a switch + a relay you can. Switch controls relay, relay switches ground wire on/off.side question. Is it possible to wire a ground switch to illuminate? What I mean is can I get light to light when switch is in the on position while only switching ground? regular illuminated switch like in picture
I originally wanted to do that but SPAL recommends only using ground switch and not interrupting 12voltWith a switch + a relay you can. Switch controls relay, relay switches ground wire on/off.
