Okay I have a question or two with wiring dual electric fans. I have both fans wired through individual relays. relays are powered from electric junction and have 30amp Maxi fuses in between. my question is whether to hook 12 volt source to keyed on ignition or constant? I like the idea of fans running after shutdown to cool motor however my fans draw a total of 44amp together. If I wire it to constant how long can fans run before they would drain battery and have restart issues? Battery is 120 reserve and 55 Ah @ 20hr rate
