'... to another post, 140 gph is too much. It will flow at a higher pressure and is too much for your application. I'm guessing you don't have over 550 hp?'
I assume that was aimed at my responce.I am not suggesting HE use a 140, it was just an example.
None of us can really give "good" advice without more info from the OP.
On a side note, Carter are the only pump that I know that allows free flow threw it when off.
Back, way back, in the day they sold a trak-pak which was a inline pump.
Years later we put a carter back at the tank inline, it was wired to the n2o arming switch. We put a T fitting where the hard line turns to rubber right near the d/s footwell (A-body). The one side went to the mech pump and the other went to a n2o solenoid.
Worked well for someone who did not know what they were doing!! Maybe we just got lucky, never hurt the motor running a 150 shot.
