Electric fuel pump
onebadasscutlass
143
detriot, michigan
I have an 84 cutlass. I have a mechanical pump and would like to change it to an electric. Is there any in tank fuel pumps that would fit in the stock tank. I would rather have that then a external fuel pump that loud. Hear is some pictures of my car. any info would be greatly appreciated
crucial118
1,055
51
48
MARYLAND, DMV
A grand national sending unit would work with a 3rd gen camaro pump or walbro 255lph pump. But you should also get a grand national tank with baffles. Don't forget a regulator because it will be 45-50psi.
crucial118
1,055
51
48
MARYLAND, DMV
Yup. That's what I used on my fi conversion.
crucial118
1,055
51
48
MARYLAND, DMV
A company might make a low pressure pump for the gn sending unit. Aero, walbro, edelbrock, etc. Not sure.
crucial118
1,055
51
48
MARYLAND, DMV
Not sure bout the 84s, but my 86 lines were already there. Feed, return, vent.
onebadasscutlass
143
detriot, michigan
Looks like I gonna have to do some research under the car I'm not sure about fuel pumps that's why I was asking all I ever ran was a manual pump. When I get under there how do I know which line is which?
crucial118
1,055
51
48
MARYLAND, DMV
Look at your mechanical pump. Are there 2 lines going to it? The bigger of the 2 is the feed, the other is the return. Do you have a vapor canister? That line is the vent.
jae
460
2
16
You may be able to also use the Monte 4.3L EFI setup. I believe this will be closer to the carb PSI setting but as stated above you will need a regulator. And please do not use a cheap (not just price but more so quality). Another reason to perhaps look for an MC setup is because everyone who says they have T-Type / GN / Turbo T parts puts a price premium on their parts, like they're magical or something. :mrgreen:
