Electric fuel pumps? (carb'd)
Here's a quote from a guy at LS1tech:
" http://www.summitracing.com/parts/CRT-P4070/
^ I would use this pump right here for a 400hp 5.3. It will have enough pressure but won't need a regulator and its rotary design is nice and quiet."
I think I might just go with this one and call it good. I've got PLENTY of other things to worry about, so cheap and easy is good. It's a Carter P4070
I have one sitting in my basement im not using as im going with the 4.3 setup myself... Anyone wants it let me know.. they can have it cheap!!!
You can call Carter they will tell you its still a gravity fed external pump best located behind and below your fuel tank with a sump or using a cell. You can go ultra cheap skip the sump or cell hide it by the axle but that comes at a cost. There is price cost and value. You can go for the cheapest possible price but the end cost might not be a good value. Is the fuel system the best place to skimp? Best of luck regardless.
