Ditto, I want to know this. I would love to use the stock speedometer spot at least. I am a bit different as I want an electronic speedometer so my T56 can give the signal.
I tied retrofitting the G van or late suburban cluster into the G body GP cluster and it wasn't anywhere close. Totally different odometer location, mounting method, and diameter.
I ended up getting a summit electric speedometer and column mounting it. It does go to 120 and have a similar sweep path.
Your only options for factory readouts with speeds over 85 would be 87+ cars. All the FWD stuff is ~90 went to 180 degree sweep speedometers with a different font so if you try to retrofit something like that in there its going to look like trash.
I ran out of ideas and gave up with a stock appearing retrofit option.
An 88 fiero might work but it is a good amount smaller in diameter, and the odometer is in a totally different spot.
Trans am stuff is worthless since the gauge doesn't match the sweep pattern of the G body stuff
