Electrical problem...
rogus
448
180
sounds like a bad ground or a dead battery are you sure the batt is good did you put a load tester on it ? it;s typical when you turn something else on it draws away the ground from what ever was working like the clock clean the batt cables on the battery and the other end of them
My cable end are clean. I took the battery to be tested and it's good.
Reactions: Sweet_Johnny
is it clean on the starter and engine block is the ground from the engine to body good .the batt could have tested good earlier how about now ? it could have had a draw that would have run down the batt charge the bat you can do that by jumper cables to another car that the engine is running
I burned a circuit in the alternator.
  • Sad
