Get the battery up to charge, unhook the cables, and let it sit overnight. Make sure it holds a good charge, like 12.8v or better. A bad alternator can take out a good battery quickly, as in, your new battery might not be so "new" anymore.
Thank you very much! Those are really nice and thanks for the suggestion! I’m more into the lowriders! I’ve checked the cables and those are good, and I’ll check the back of the alternator I only checked the voltage on the batteryWelcome to you and your son, you two will like it here...that is a great looking Regal....
I would go with flemming442's suggestion and look at the battery cables and make sure the ground is clean. Have you tested what voltage you are getting at the back of the alternator compared to the voltage your getting at the battery with the car running?
I’ve checked those as well and the cables are good and out of the way, but the engine will run for about 20 minutes after starting it then slowly dies out. Every time I have to jump start it just to get it going againGiven your run time before shutdown, you should probably check your battery cable routing. It sounds like it's laying on the exhaust- pipe gets hot, insulation softens, cable shorts to ground....
When the car is powered off, you could also make sure that the current draw from the battery is minimal.
Im thinking that when the car is off, you need to check the current draw with an amp meter.I checked that before I started it, and it was reading 11.45
