first things first, theres also a possibility that theres a broken ring.
second, pour some in slowly and have it idled above 1000rpm, then after it runs for a couple minutes after you do that bring idle up again and pour the rest in until it stalls. if it doesnt stall you have too much blow by in your rings (the whole reason you are doing this is to get rid of that) then start it again and take it for a good long hard run. that should clean the rings good. hope this helps a little bit.
