you do want the basics of the EVAP system. it will keep vapors from building up in the tank.
you need the O2 sensors for the engine to work correctly. the computer needs to know what the actual A/F ratio is.
the biggest thing is going to be establishing a new program for the ECM. if done right you can have fuel economy at cruise and max power. it can also limit things like the EVAP functions to only what is necessary. you will want to consult an expert on this. or get an aftermarket ECM and software that you can program with a laptop.
