Engine running hot in traffic
I've chased this problem before. You have one of three things going on. Either too much initial timing, which I kinda doubt, not enough airflow at idle, or not enough water flow at idle. Are you using all the stock pulleys off the 305? If so it's not a water flow issue. Many aftermarket pullies are smaller and slow the water pump down.
Reactions: Wraith
What amperage do the Intrepid fans pull? I can tell you my Stratus fans have fried many relays and thermal switches. I think one 40 amp relay isn't enough. The fans are cheap at the junk yard, the controllers are not. I have had 0 luck with the cheap and mid priced controllers.
I have cloud car fans on my car also and I wired one to a controller, and the other to a relay for always on when key on. Did you rewire the fan motors so they were always on high, or did you try to make use of the high/low wiring that they came with stock?
Here is a Wiring Diagram I would recommend for a dual fan set-up:
Always on high and I now have a manual toggle switch that is fused and hooked directly to the battery. I have blown 2 relay boards on my Flexalite controller, I may just hook it to one fan when I get a replacement board. The other fan will stay hooked to the toggle switch and also the second relay and I may be just bypass the push in probe since it isn't working.
Yes i reused all the stock pulleys off the 305. I also forgot to mention also thay Iput on a high flow aluminum
I'm betting that the fan clutch doesn't engage until close to 200*. Take that thing off and put a pair of intrepid fans and a relay on it if you want it to run cooler.
And yes it doesn't seem to engage until temp reaches around 200 degrees.
Should I get a new fan clutch? Thought about putting one of those black plastic 7 blade fans on it. I run those on my demo derby truck and it pushes a lot of air and keeps that engine cool when I make it talk for about 20 minutes wide open.
Yes i reused all the stock pulleys off the 305. I also forgot to mention also thay I put on a high flow aluminum water pump.
Should I get a new fan clutch? Thought about putting one of those black plastic 7 blade fans on it. I run those on my demo derby truck and it pushes a lot of air and keeps that engine cool when I make it work for about 20 minutes wide open.
You can just cut the wires to the probe and use a thermal switch, as long as the probe is a switch and not a thermocouple.
Reactions: Longroof79
200* isn't too hot. That's where the fan clutch is designed to engage so it doesn't get much hotter. A flex fan is fixed and will keep the engine closer to thermostat temp assuming the rest of the cooling system is good but will cost power and mileage.
I stand corrected, bad relay, brand new! It just clicks touching the two wire connections on the probe. This is my issue with electric fans, the shitty controllers.
