I knew that a flex fan would rob power but I'm not sure what else to do. I could put the electric fans on. They can be ran through my Sniper efi. I kind of wanted to stick with a stock look and regular fan. I may try Longroof's setup. And yes the flex fans are noisy.200* isn't too hot. That's where the fan clutch is designed to engage so it doesn't get much hotter. A flex fan is fixed and will keep the engine closer to thermostat temp assuming the rest of the cooling system is good but will cost power and mileage.
