Just a quick question how for do you go in tearing down a block before it has to go to the mechine shop?
It may be a better choice really and truly but I have spent a good amount on mainly the top end of my engine with intake, carb,distributor,cam and lifters, valve springs,clips and all also new timing chain, I have all these parts and I just seem stuck.!! If you know what I mean. I really appreciate everything you had told me. ThanksThere is a lot of info (books) on rebuilding SBC - I would suggest googling or buying a book and follow it to find out what can be used and what needs replacing. I would keep a tab on what you need to do, depending on machine work and parts - a crate engine might be a better choice
I also have a book as well .thanks again looks like I May need to do a little more research. Thanks for helping out appreciated it.!!It may be a better choice really and truly but I have spent a good amount on mainly the top end of my engine with intake, carb,distributor,cam and lifters, valve springs,clips and all also new timing chain, I have all these parts and I just seem stuck.!! If you know what I mean. I really appreciate everything you had told me. Thanks
