I want to know what is a normal engine vacuum psi i was told mine is 9 or 10 psi at idle and drops to 5 or 6 in gear and that's not normal the only problem is i bought my car with the motor in it and the guy couldn't give me the specs of the cam,heads,pistons,etc cause he didn't know it he only new that it had stock block,lunati master cam,flat top pistons,ported heads,victor jr intake ported to match the heads,and roller rockers. So no one cant figure it out without taking things a part to investigate.So my main question is whats a normal psi and what might i do to change the psi.
