Hey guys, I have some questions about my exhaust I plan on running. I really want your suggestions and input. I planned on running the 3" Pypes exhaust system with 40 series flowmasters, I also have some 3" QTP electric exhast cut-outs that I planned on running right after the collectors on full length hooker headers. My questions are, Should I run the electric exhaust cut-outs or is that excessive? Also is 3" too large for my application or should I run smaller exhaust.
My motor is a 383 Stroker with 10.1:1 compression, and I plan on running a head combo from Trickflow with aluminum heads and a 246/254 cam the whole combo is rated at 500hp. Here is the part number from Summit Racing TFS-K314-500-450. I will be using a victor Jr. manifold and a 750cfm carb.
The car will mainly be used on the street but may seem some track time if I can find the time to get down there. Any and all input on the motor/exhaust would be much appreciated. I want to get all my suggestions before I go ahead and put all this money into the car.
Thanks for all your help and suggestions.
p.s For those of you who requested I check on parts for you, no worries I have not forgotten. I will be back out and about after this week. We had a bad batch of storms roll through my area and I will be back out getting those things for you as soon as it clears up some.
