This has been a debate for a very long time. Some people see the remote solenoid as a crutch for inadequate wiring, others will do nothing else. I can see the logic of both. One big problem comes from the removal of the factory heat shield from the starter and to a much lesser degree the removal of the front starter brace. These are usually left off in a starter swap or removed during a header install. Larger wires and new cables and a heat shield will go a long way to provide the proper amount of current to the stock components. With stock exhaust manifolds there is enough space between the exhaust and starter that the heat shield probably isn’t needed anyway. But take off the shield and put some thin wall headers right next to the starter and you are getting the components much hotter and resistance goes way up, requiring more current to operate. The remote solenoid works because it provides more current to the stock components and allows them to operate as they should.
I remember 32 years ago when I rebuilt my ‘76 Malibu and swapped in a 355 with headers. It originally had a 305 and cast iron manifolds and the heat shield and front brace were already missing and were not added to the new engine because I didn’t know they were supposed to be there. I drove the car as a daily driver with mostly short trips. Any longer trips I took I shut down the car and didn’t have to restart it for a while, so I had not trouble starting it. One day I drove about 50 miles and needed to stop for gas, I got back in the car and it wouldn’t crank. I didn’t know about heat soak and didn’t know what the problem was. The station owner helped me push the car away from the pumps and after about 10 minutes it fired right up. I later heard about the remote solenoid setup and added it to the car and never had any trouble starting the car ever again, no matter what the circumstances. I have installed it on three of my other cars since then and did it on a friend’s Nova that had bad heat soak issues and it always worked great. I even had a flex plate issue on my El Camino and while the bad flexplate did chew up a couple of starters, it wasn’t because of the remote solenoid. It would have done the same thing without the remote solenoid.
