I used the 610-323's with the factory rotors so I could bolt on the GTA wheels on the front with wheel spacers pressed right in with no issues
I've used Dorman studs as stock replacement on other cars with no problem. Again these are also temp.I would never use Dorman products for wheel studs and the 610.023 have a 0.504" knurl diameter which are too large to fit the .486 " hole. Moroso charts say the interference for a wheel stud is 006-.016 in a steel axle so for G body stud that works out to a .492" to .502"
I don't know why I didn't just think to drill them out with a 1/2 inch bit... I just canceled my order from Summit and ordered the Jegs extra long studs. I may run a hub centric spacer in the front to clear the brakes I'm piecing together.I've used those dorman studs on my car and they seemed to press/fit the same as the stock GM ones that came out.
I will be honest, I wasn't a huge fan of the quality of the stud. It didn't have that nice crisp black oxide coating the stock ones did, they just seemed cheap, probably from the zinc coating them had. They seemed to hang up on the lug nut easier also when tightening. The thread form was probably correct but the coating seemed a bit heavy.
I ended up going with these morosso studs for the rear of the car since to be semi drag race legal you need to have extended studs and I swap between shank lug nut wheels and acorn style so having a good strong piece of hardware was important to me.
Plus my moser 30 spline axles came with either screw in or press in holes for the studs. The screw in were 7/16" and since I had metric threads on the front already, and everything I own has metric studs i just wanted to keep it consistent. The moser press in stud diameter was too small for the 0.509 knurl that the morosso studs came with so I use my hand drill and drilled the holes out to 0.5". They pressed in nice with the hole opened up.
Moroso 46245 Moroso Wheel Studs | Summit Racing
Free Shipping - Moroso Wheel Studs with qualifying orders of $109. Shop Wheel Studs at Summit Racing.www.summitracing.com
I think a 0.509" stud needs a 0.5" hole and the 0.504" or whatever the dorman stud has works OK with whatever the GM stock rotors are drilled for as long as they were metric to start.
I think the ~0.485" diameter that has been thrown out is a 7/16 knurl size and seems to match what the moser axles I bought had, since that hole was way too small for the M12 knurl.
Dorman studs are $12 for a set of 10, Morosso studs are damn near $70.
