F-41 vs standard steering box
10,569
14,312
This is driving me crazy. Are the F-41 steering box and the standard steering box totally interchangeable or not? RockAuto's CARDONE rebuilt specs show two different spline counts on the input shafts. I have never seen this or even heard about it. Are they the same- or what? It would not be the first time RA screwed up specs but this has me chasing my tail. Here is the F-41 page: https://www.rockauto.com/en/moreinfo.php?pk=31245&cc=1246924&jsn=413 and here is the non-F-41 page: https://www.rockauto.com/en/moreinfo.php?pk=31205&cc=1246924&jsn=411&jsn=411 See the spline counts? And worse, Jeep lists the F-41 35 spline box as used on the Cherokee. So using the popular Jeep steering shaft would require you to change to an F-41 box if you had the standard box. IF the splines were different. So what gives?
Ribbedroof
4,923
7,059
Wellston, OK
I swapped an f41 box into my car with no changes.
Ditto. Replaced a 605 box with a MCSS box and pitman, used original-to-the-car intermediate shaft
DRIVEN
8,079
14,556
*CENSORED*
Same here. IIRC the Pitman arm is box specific though.
10,569
14,312
OK so the input shaft is the same. GREAT! I know about the Pitman arm, not a problem. I guess CARDONE got it wrong. Awesome, guys, thanks!!!
9,194
15,446
Sure you're not looking it up as a Cutlass Supreme cause as we know nothing fits a Cutlass Supreme.
