Failed smog today
it could be the timing is off or a vacuum leak. I wouldn't touch the carb until you check others things first
Well, here in California they check the timing when you get smogged, and the tech said it was within spec. I'll look for vacuum leaks, just spray some carb cleaner around the lines?
Dave V said:
could be the cat or egr valve if it has one....
If the problem were the cat, wouldn't I smell something in the exhaust? Are there simple tests for the egr?
Hey guys, would running seafoam through it help him out any? Dont have smog checks in TN so just a shot in the dark
