Alright, I’m about to embark on a pretty wild journey with my engine. I’m going to swap over to E85. I want say why the corn juice is the path I’ve chosen. However, I do want input if you have any.
If you have read this far, you know the #FamilyBurnoutWagon has a supercharged small block, every detail of which I have put below. It put down 401 whp on 4lbs boost and pump gas (91) when it was 110 degrees outside. But I want more. . . obviously.
The concern is, at 4lbs boost, my calculated static compression ratio is 11.4. With timing set at 14/34 max and the MSD BTM cutting 2 deg/lb, I should have a max of 26 deg advance. The air fuel ratios I keep pretty conservative because of how hot it is in Las Vegas. This is super safe setup I run down the highway with the AC on taking the kids to soccer. Occasionally it will smoke from the back tires a whip wildly in circles when I feel moved treat the loud-pedal like an on-off switch, which almost never happens. . .
Theories. . .
With 100 octane petrol in the range of $8.00/gal and only allowing a 12:1 compression ratio, it won’t be a big enough boost in power to be worth the extra dyno numbers. I want to wheelie!! The corn juice boasts a generic 105 octane number which should support about 10lbs of boost, according to vigorous googling. In an on all cylinders article I’ll link below, they ran a 10.1:1 compression ratio engine with 9 psi boost safely on the dyno. This is a calculated 16.1:1 compression ratio with no reported problems. So, shooting for 15.1:1 should be safe. Also, running the corn juice on the rich side for safety doesn’t cause the loss of power as petrol base boom juice. Not to mention the benefit of cooler cylinder temps and being able to add some timing to the extra boost for some extra power. I’m interested to see what this swap will do to the power output of the #FamilyBurnoutWagon.
Most of the mods below are in the videos on my YouTube channel if you are interested.
The current engine is out of a 1996 Chevrolet Pickup. It is a Small block 350/5.7 L31 engine. The specifications are all below.
Stock: rated 9.4:1 (calculated 9.1:1) using: https://www.summitracing.com/popup/calcsandtools/compression-calculator
Bore 4.00
Stroke: 3.48
Head chamber size: 64cc
Valve size intake: 1.94
Valve size Exhaust: 1.50
Piston dish: 12cc
Piston to deck clearance: 0.025
Fel-Pro Head Gasket Part number 1034
Summit Racing Part Number: FEL-1034
Gasket Material: Steel core laminate
Compressed Thickness: 0.041 in.
Cylinder heads are Aluminum Blueprint H8002k:
Combustion Chamber: 64
Intake Runner: 195cc
Exhaust Runner: 75cc
Intake Valve: 2.020 in.
Exhaust Valve: 1.600 in.
Valve Springs: COMP Cams 986-16
Maximum Valve Lift: 0.575 in.
Guideplates: Yes
Valve Guide Material: Manganese bronze
Valve Seat Machine Style: 3-angle
Valve Seat Material: Chrome nickel
Rocker Arms: Summit 1.5 Aluminum Roller SUM-G6935-16
Pushrods: Edelbrock 5/16 in. dia, 7.2 in length, 0.080 in thickness, Heat-treated Chromoly, p/n 9653
Valve Cover: SUM-440601-L Tall Fabricated Aluminum Valve Covers
Camshaft: COMP Cams Nitrous HP Camshafts Hydraulic roller 08-301-8
Grind Number: CS NR276HR-113
Basic Operating RPM Range: 2,000-6,000
Duration at 050 inch Lift: 224 int./236 exh.
Advertised Duration: 276 int./288 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.502 int./0.520 exh.
Lobe Separation: 113
Supercharger: Weiand 144 blower
https://documents.holley.com/199r10243rev.pdf
Stock compression: 9.1:1 + 4psi = 11.4 compression (401 whp)
Timing: Summit HEI and MSD 6462 6-BTM Ignition Control Box
Fuel: Customized Holley 4150 style 750 CFM Vacuum Secondary with Boost Referenced Power Valve
Proposed ability on E85
Stock compression: 9.1:1 + 10psi + 15.1
Article:
https://www.onallcylinders.com/2015...eans that you could,to 16:1 compression ratio.
Theories. . .
Bore 4.00
Stroke: 3.48
Piston dish: 12cc
Guideplates: Yes
Article:
