RACING Fastest Drag race Forum cars!
wingnutks
420
1,314
Went to the track to get an NHRA license today. These are the last 4 runs after making the 1st 4 slow runs. Pedaled on every run, The 2nd slip from the left and the one on the right I pedaled twice. SMH.
Did u get an Arb installed?
5,716
12,233
5,716
12,233
Glad you said that... I was about to get all judgy about your inconsistencies after the very consistent 60' times. LOL
Thing is booking.
I had it turned don so far from where it's been in the past. I was shocked to see it run the speeds it did. I've hit at 18 degrees and 9psi last year, and this was at 3-3.5 psi and 11 degrees and spun like heck. And it should be much more capable than the 21-22 psi I was running in those 4 runs. At some point I'll be aiming for 30-35, just in small steps.
Supercharged111
4,943
7,740
Colorado Springs, CO
Can you rig up what the Japanese call a boost scramble button? It's like a NOS button on the wheel, but when you hit it it ups your boost. Seems you could run it low to get out of the gate and send it once it hooks. Sounds like an easier solution to an inconsistent car/driver than relying on it doing the same thing every time.
5,716
12,233
Yup. I’ve messed with it a little bit and it works. I can put it on the same switch as the bump switch and it only activated when the car is moving.
I have it in the factory cruise set switch. The cruise on/off has to be on, then it’s active.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Making some jam to trap 140! Nice work!
DRIVEN
8,079
14,556
*CENSORED*
Read it and weep, ladies.
  • Love
Reactions: 8 users
DRIVEN
8,079
14,556
*CENSORED*
I tried swearing at it, I tried spitting at it, 305 gave no ****s.
