Back to the engine.......Once I had the long block completed I picked out accessories. I wanted to keep the R4 compressor and lines I was using on the old small block. I also wanted to keep a separate belt for the blower. The best compromise was the LS3/LSA water pump spacing. To go along with this I used C5/C6 Corvette accessories on the left side (alternator is from a C5 without the decoupler pulley, ps pump and reservoir). ICT Billet has compressor brackets that fit PERFECTLY. I did not even discharge the system. I laid the compressor to the side while swapping the engines and when the LS went in the compressor dropped right in place with NO modifications. The power steering pump clears the steering box by about 3/8".
