Yesterday I started my first build, 355 sbc. It ran fine for the first 20 mins, shut it down to check fluids and finish up some wiring. I restarted it and dicided to take it around the block, when I got back, it was making a pinging sound, kinda like a dead cylinder. I messed with the timing a little and it stopped for a second then came back. The temp gauge was reading 210, but the valve covers were to hot to even touch! I decided to put it in the garage, but while doing that it started to smoke out the passenger side tail pipe pretty bad. It was white smoke, so today I pulled the head. Number 7 had water in it, but I dont know if that was from me loosening the head bolts? The front set of head bolts broke free very violently, while that back set broke free like normal. I am going to check the head and see if its warped.
To make matters worse, the intake valves have oil sitting on top of them on the runner side. How do I know if I installed the umbrella type valve seals correctly?
ALSO, while pulling it into the garage I was hearing an inermitent valve train rattle type of noise. It was to fast to be bottom end. The picture of the head gasket made me think the water in the heads got so hot it turned to steam which made that sludgy stuff.
Thank you for any advise in advance.
Specs- 355, summit vortec heads, 10.2:1 compression, forged flattops, felpro steel shim head gaskets, rpm performer intake, speed demon 650 carb.
