Throttle body injection, this car is just a play toy at this point, This is the kind of info I am looking for,FiTech came with a bang because o the price point. At the time Holley only had expensive TB setups. Since, Holley has become very competitive. The support for Holley 10 times what the FiTech stuff.
Are you wanting a throttle body (TB) setup or mutiport injection? Cruiser or racer?
I try to buy from Competition Products in Oshkosh WI, they are only a little more then an hours drive for me and had great service from them. I do see Holley has a sale on the efi units.I have a Holley Super Sniper. It will do a lot more than I have it doing. I had a problem with it right off the bat, but Holley corrected it fast and free. Super easy to set up. When you add boost and veritable timing is where it gets a little tricky. I suggest you buy what ever brand you want through a known dealer not Summet or Jegs. That way if you have trouble you can talk to your rep. Holley dose have a forum and tech support for there products. For what you probably are going to do with it? A Holley Sniper would work well for you, and later you can buy a distributor that will let you have veritable timing if you want or you can run a HEI.
Is that parts you buy or modify from a carb. The you tube videos i saw people were robbing parts off carburetors. And can you buy one already set up this wayHolley sniper is great. Only thing I am in process of doing is to change to a progressive secondary throttle so the hit will not be immediate out of the gate.
