This has been asked a handful of times in this thread and has been ignored.....I was wondering this as well. My clutch fan has been more than adequate for my 305. I’m only removing it to switch to electric.
Yes, the 1998 to 2005 Dodge Stratus/Plymouth Breeze fans I had on my 88 Cutlass were similar and fit a stock G body radiator very well and move a lot of air. The Davies Craig 80 amp controller works great to control the fans, unlike the cheap controllers.If anything I would look into going with an electric fan set up when the time comes, this is the one I have in my Regal.
The Intrepid dual fan https://www.summitracing.com/parts/fss-75203
You can do it pretty cheap just using toggle/rocker switches with some high amp relays, fuses and wiring.
A quality fan controller will be the most expensive add on
