The spacer on my motor is 2".Wanting to replace my stock coil fan with an aluminum flex fan...
'84 Monte Carlo 305 SBC
I have a stock fan shroud and a long water pump...
What fan size and spacer size would I need ?
I don't know,that thread provided a lot of popcorn for this kid.7 pages in a day.
Why is everyone trying to talk Tynan out of a flex fans? Because they are a gimmick. At their inception it was deemed they were less of a drag on HP, they are lighter, and they offer more cooling (air flow) at low rpms than they do at high rpms because less air flow is needed from the fan for 10 second blasts at WOT/high rpm's. That is all pretty much marketing BS. The proven facts is that they will identify any type of cooling system issue. Meaning if your cooling system is marginally keeping your engine cool, then the addition of a flex fan will put it over the edge and you'll have overheating issues. And most importantly, they are dangerous. Personally, I couldn't live with myself if one of these blades came off and hurt someone - forget about damage to the car because that can always be fixed.
Other than that, measure your shaft from the water pump pulley surface to your current fan blade mounting surface. I'll go out on a limb and say that any spacer from 1.5-3" will work.
p.s. I asked him to measure his shaft. And I think if he put all of these threads together, then this could give the flat cam BBC thread a run for it's money on the 100+ page length in to general discussion area.
Cool, that's what I bought...👍🏾The spacer on my motor is 2".
