Another thing to consider is future availability.
If you plan on owning your car for like ever and ever, than you may want to closely consider making the upgrade.
The factory cable is a G-Body part only, one of which only came in select models at that. Probably only 10's of thousands of these applications are out there, where as there are probably about a million people that have a B&M or Husrt shifters. So as time goes by, they(factory replacement cables) will become increasingly harder to find vs. the B&M cable.
I think most people do not know they can upgrade just the cable(in combination with the trans bracket), and have it work properly with their factory shifter.
I would also like to add that factory replacement cables from local auto houses are made to fit all G-body's, so they are @1.5 inches longer than the Cutlass cable(because the extra length is needed for the Grand Prix). Yes, they fit and work, but they aren't the same as a "from the factory original". Some of you can probably testify to this.
