Get a TBI 305 flywheel. And go to at least 3.42s
Racing or not I'm assuming you're planning on dropping the hammer time to time. On a 35 yr old trans that was weak to begin with that's all it takes
I was looking for a good flywheel and clutch like Ram Clutches. Ram makes a 168 but not a 153 tooth flywheel and their 11" clutch is $40 cheaper then their 10.5" clutch. Not that the price matters but its a bigger clutch for less (probably because it is more popular)
I just noticed Hays makes a 153 tooth flywheel for a one piece rear main, 1986-1993
Are all one piece cranks, 1986 to 1998, 305 and 350 balance the same?
As For the 3.42 gears...Do the math... with my 3 speed transmission ratio of 3.5 x 3.42 = 11.97:1 for the first gear ratio!
That is more then a 4.56 in a TH350 (2.42 x 4.56 = 11.49:1)
Not to mention it will be 3000rpm at 70mph with 27" tall tires on the back VS 2400rpm
I am confident the trans will take a beating. I've owned these before and I've seen them used in many stock car / race cars over the years.
Yes she's 35 years old but only has 20,000miles on her.
