I searched some but didn't find the answer I was looking for or I just overlooked it...will say a 4dr malibu, Lemans etc g body frame work on a 2dr g body malibu, Lemans from 78-80 ? Thanks
As far as I know yes I believe Monte Carlo is longer in front thoI searched some but didn't find the answer I was looking for or I just overlooked it...will say a 4dr malibu, Lemans etc g body frame work on a 2dr g body malibu, Lemans from 78-80 ? Thanks
Thanks. Just talking 78-80 g bodies. Still hold true mr clutch? 4dr to 2 dr?As far as I know yes I believe Monte Carlo is longer in front tho
As far as I know I've never done it but with all I have done and all I've seen or read it should be the same I would just take some measurements to make shore besides that way you can make shore the Donner is straightThanks. Just talking 78-80 g bodies. Still hold true mr clutch? 4dr to 2 dr?
Monte Carlo frame is the same as the others.As far as I know yes I believe Monte Carlo is longer in front tho
Do you know much one has to relocate the rear frame mounts and what the process is in doing so? I'm thinking about getting an LS swapped cutlass wagon but I'd like to put a coupe shell on the frame if feasible.No offense to you on a personal level 83, but your post contains some of the same inaccuracies that keep being repeated.
In Malibu world:
Wagons, sedans and coupes all are the same length. El Camino (Caballero) by virtue of it's longer wheelbase, is longer.
Coupes and sedans use the same frame, same mounts, direct swap. Wagons will interchange with these IF the rear mounts are relocated to address the differences in fuel tank/spare tire provisions.
Regals, Cutlasses, GPs, Montes are longer in front, I recently posted pictures of the difference.
I have some literature here that I could provide GM part #s for the frames through 1981, and I think I have the later stuff packed away.....if we wanted to make a sticky I would be happy to compile it
