frame interchange
malibujustin
333
424
I searched some but didn't find the answer I was looking for or I just overlooked it...will say a 4dr malibu, Lemans etc g body frame work on a 2dr g body malibu, Lemans from 78-80 ? Thanks
Clutch
5,191
10,928
Brick NJ
As far as I know yes I believe Monte Carlo is longer in front tho
Clutch
5,191
10,928
Brick NJ
Thanks. Just talking 78-80 g bodies. Still hold true mr clutch? 4dr to 2 dr?
As far as I know I've never done it but with all I have done and all I've seen or read it should be the same I would just take some measurements to make shore besides that way you can make shore the Donner is straight
-83MONTESS-
4,570
967
Bellevue, Ohio
Monte Carlo frame is the same as the others.
The only difference is the El Camino and the Wagon frames being longer in the rear, I believe. In 85ish the 200-4R overdrive transmission was made available so the frames had the driver side cross member frame extension on them to compensate for the longer transmission that pushed the crossmember farther back. Thats really the only difference. I have an 82 Regal frame under my 87 Monte Carlo SS aerocoupe.
Ribbedroof
4,973
7,208
Wellston, OK
No offense to you on a personal level 83, but your post contains some of the same inaccuracies that keep being repeated.
In Malibu world:
Wagons, sedans and coupes all are the same length. El Camino (Caballero) by virtue of it's longer wheelbase, is longer.
Coupes and sedans use the same frame, same mounts, direct swap. Wagons will interchange with these IF the rear mounts are relocated to address the differences in fuel tank/spare tire provisions.
Regals, Cutlasses, GPs, Montes are longer in front, I recently posted pictures of the difference.
I have some literature here that I could provide GM part #s for the frames through 1981, and I think I have the later stuff packed away.....if we wanted to make a sticky I would be happy to compile it
Ribbedroof
4,973
7,208
Wellston, OK
To answer the original question, the Lemans/Grand Lemans/Grand Am carry the same part numbers as the Malibu version for the frame assembly. There are some minor differences regarding park brake cable type and engine mounts when using some later frames on early cars...this is noted in the GM parts books
malibujustin
333
424
Thanks for all the replies guys. Messed up frame on friends late 78 mc. Trying to help find a fairly direct bolt in. I think I made some confusion with original question. Meant to type would the 4dr frame go under 2dr monte. Sorry guys. Again thanks for the info that has been provided.
WizardCum
n00b
Apr 18, 2016
Omaha, Ne
In Malibu world:
Do you know much one has to relocate the rear frame mounts and what the process is in doing so? I'm thinking about getting an LS swapped cutlass wagon but I'd like to put a coupe shell on the frame if feasible.
