Those look nice. Any mods to get them rims to fit on the car? Any regrets going with 17s? I like to play around and get on it with my car
Thanks, I have F body spindles so they kick out the wheels about 1/2" per side and a 67 A body rear with is 2.5" wider than the G body rear. I had trim the inner fender at the back but if you have G body spindle they have a smaller arc so with G body spindles you may be ok. I have .75 negative camber but I still had to fold the top of the fender in a bit. I have a Delphie 600 box so I had to put some stops on the lower control arms so it would not rub the 36 mm sway bar. If you have a stock sway bar and steering box you shouldn't have that problem. For the backs I had to roll the quarter panel a little. The wheels have a 4" BS
