Boy do I wish I heard of the way the last 2 posts do it days ago. I got it done with the compressor and jack. I cleaned the frame pocket where the sprng seats real good, then glued the isolator where it’s going to live. Now it’s on to steering arms and total brake system replacement/upgrade. Thanx for all the adviceI use electrical tape to hold the isolater on. And I leave the ball joint connected and undo the two inner mounting bolts and lower the arm down that way. Put the spring into position and jack the arm back up by the lip between the two bushings. It may take a little bit to get the bolts lined up and a tapered punch will help. No spring compressor required. I've been doing it that way for years without an issue. I even did it that way last summer on my 442 and used moog 5610 springs which are just about the tallest g body spring there is with no compressor.
The Moog 5660s are a really strong stiff spring that were a real “EX WIFE “to replace . The compressor had a tough time.Stop a minute. You are using shorter springs and you are still having trouble? Something is wrong. Front springs are hard but not that hard. Unless your spring rate is substantially higher it should "go right in". I used quotes because obviously it never does. But I've done full size Chevy trucks and haven't worked as hard as you are describing. Look for the obvious problems such as things hanging up. The old isolator still in there hiding out. Something like that. I always use a floor jack under the control arm. Make sure you as far out under the ball joint as possible. Not under the spring. You want leverage. Loosen the upper ball joint and pop it so you can gain an inch or so of additional length in the spindle. Jack the back of the car up higher than the front to shift more weight onto the front. Get a few friends and have them sit in the car.
Good luck and be careful
