I'm getting my motor together right now and wanted to start thinking about suspension. My G is going to be a daily driver capable of some spirited driving, therefore budget oriented is what I'm after.
I'm currently working with Energy Suspension body mounts, 1.25" front sway bar, and Del-a-lum LCA bushings. I will buy tall lower ball joints and plan on boxing the frame.
What else can you guys recommend? Is there anything I can do with the upper control arm to improve geometry or is aftermarket the way to go? What spring and shock combo is preferred? I'd appreciate any input you have.
Austin
Austin
