i'm having 2 problems with my carb that i hope y'all can help me with. the carb is a holley 4175, refurbished by holley.
first problem; i have the carb tuned correctly but the idle mixture screws are almost all the way in (leaned out). the engine does die if i turn the screws all the way in. the throttle valves are closed. can the floats cause this if they are too high?
next problem; not sure if it's a carb problem or not. if the car sits for a couple of days it takes awhile to get fuel pressure up. i'm using a mechanical fuel pump. there are no leaks.
any help is appreciated.
