Sloppy stage 2 turbo cam. It's very mild. Also when I threw the external fuel pressure regulator in the return right after the rail I dialed it into between 58 and 60 psi and still no go. It would idle at that set psi all day and if I took the vacuum off bump up a little but then drop again under load.
