All right need some ideas. My fuel guage stopped working on my ls swapped 80 malibu because the sender went bad. Replaced the sender fuel guage works but now I'm have a fuel pressure issue. At idle and light cruise I sit around 44-48 psi then even under medium/light load pressure drops quickly. Down to single digits and goes lean under heavy load. I did run the pump dry a couple times so thought maybe I hurt it so replaced it with a different walboro 225 I had lying around. Same result. Pulled the tank did continuity checks and all checked out. Put a new strainer, tank is spotless, back washed the 10 micron filter clean as a whistle and tried a run with it bypassed, blew out the feed lines with compressed air, even threw a new pressure regulator at it nothing. added a second thicker ground today just to be safe. Anythoughts or ideas? Car ran flawlessly before replacing with an identical sender.
