I like this thread. I had same questions. I found a gas cap with a lil push button to vent. It came off a 88 Cadillac and fit like a glove on my regal
You can also buy them new for less than 10 bucks if you wanted that kind. Click on the "Robot Check" link below. WTF?I like this thread. I had same questions. I found a gas cap with a lil push button to vent. It came off a 88 Cadillac and fit like a glove on my regal
Yea i know, i work at lkq so most of my build has been from parts out here.You can also buy them new for less than 10 bucks if you wanted that kind. Click on the "Robot Check" link below. WTF?
https://www.amazon.com/dp/B000C5CEPC/?tag=gbody-20
I did an engine swap from the small v6 to a 307 with 4bbl about 2 years and I am still using the original throttle cable in my 78 CaballeroTo be honest I used the original 229 cable when I went to the 305.
In case I replied in the wrong spot, I will answer again. I did an engine swap in a 78 Caballero from the small v6 to a 307 with 4bbl and am still using the original cable.Anyone with info on the throttle cable length ??
Heading to the speedshop to get the vent.
