Ready for this age old topic?
Currently, I have a steering shaft from the 84 to 94 Jeep Cherokee installed on my 80 Monte Carlo. I am not really too happy with it, as it has some sloppy play where it telescopes. From what I been reading, the 95 to 98 Jeep Cherokee is a better option, as it will telescope but not have the slop because of a plastic sleeve?? At least that's what I read about. There is the borgenson $300 intermediate shaft out there, but I am unsure of the telescoping sloppyness and over $300 seems a bit steep.
There is an aspect of these G-body intermediate steering shafts that people seem to disregard. These vehicles are not a unibody construction, which means that the frame and body will flex independently of each other. Even though I have brand new polyurethane body bushings installed, there is always some frame flex and body movement. If you look at the old OEM rag joint shafts, the upper part of the shaft that connects to the steering column has a joint that provides excellent telescoping with zero turning slop.
I am almost thinking about going back to a new OEM style rag joint intermediate shaft. I really don't feel like the rag joint play is that noticeable, at least better then metal to metal slop that you can feel in the steering wheel.
Any thoughts on this?
