I was just sitting down and calculating some changes to the weight distribution of my car, and came across an interesting bit of data in one of the Oldsmobile brochures from my "library". It's a 1987 one that is named "87 Oldsmobile Performance Report". In it, the listed weight of a Cutlass 442 with a 307 is 3,203lbs. It seems a bit low to me as I have seen data that suggests it should be around 3500lbs. Has anyone here bothered to weigh a dead stock V8 2 door G body?
The other thing I have read in the past is that the weight distribution is 60/40, but I also wonder if this is correct? I am trying to get my car down to around 55/45 without removing any optional equipment like the A/C, so I wonder how much there is to go? I made a thread about component weight in the How To section of the forum http://gbodyforum.com/viewtopic.php?t=5121 to try and discuss what things weigh and look for good places to remove them. At any rate, I calculated that with an aluminum: Hood, heads, water pump, radiator support, radiator, and bumper support, plus a Civic battery, mini starter, plastic head lights and headers I should be able to trim around 170lbs off the front, enough to shift around 2.2% of the weight to the rear of the car if it weighed 3300 lbs to start with, and it would knock the weight down to 3130lbs ( about what a new Civic weighs). If it's a 3200 lb car, it then will be just over 3,000lbs-which is great for a large car with all the toys. I also figured I could switch to rack and pinion steering for another 10-20 lbs and tubular control arms for another few pounds. Swapping to a Sanden A/C compressor may also be worth a few pounds, but I really have no idea what they weigh. Lighter seats from a Civic or Integra could be worth another 50 lbs according to my scale, but I don't know if I want to do that.
Anyhow, anyone know for a fact what these cars really weigh stock?
:EDIT: I found more road tests, and the distribution varied from a good of 55.4/44.6 for an 83 MCSS, to a bad of 58.2/41.8 for a car I cold not see the right page for. It was an article comparing the MCSS vs the 442 in 1985, so I assume the 442 was the worst of the two since the Olds engine I think is heavier than the SBC. Weight varied from 3200-3600+ in the different road tests carried out by Car and Driver and Motor Trend.
