I had to modify that same crossmember for use with my T5. The transmission was sitting way too high. Check out posts 387-388 and then 403 in my build thread.....
Both yokes
I do not know for sure, but check your your U- Joints for bad or going flat needle bearingsMy transmission agle seems wrong. With the car on the hoist and the frame level, the transmission is tilted up 2.5 degrees at the rear. When I drained the fluid it actually came out of the front of the pan first. That's what made me notice it. The angle between my trans and driveshaft is 7 degrees which seems like way too much as well. I'm measuing the trans angle off the pan rail surface. The trans is mounted using a G Force crossmember for my 700R4 and energy suspension mount pn 3.1108G. The small block chevy is mounted using stock car clamshells on the engine and factory style V8 mounts on the frame. Also, I am getting vibration at the big end of the drag strip and I believe it's coming from the driveshaft to trans angle. Trying to figure out where I went wrong? What's wrong with this combo?
