Gauge / Cluster repair 78 Malibu
Gregc
13
I have a 78 Malibu classic with two gauges (fuel and speed). Neither works. The speedo use to bounce around the speed I was going and has since stopped reading at all. The fuel shows Im at full all the time until gas is low, then it begins jumping to empty. Blinker indicators also don't read. Do these sound like problems ONLY at the gauges?
12,177
9,796
Well the speedo could be a bad cable. To determine that, get yourself a cordless (or corded) drill, disconnect the cable end at the trans and connect it to your drill. Set the drill to turn counter clockwise. If the speedo registers you know it's the cable...if it doesn't, then the speedo head is in need of replacement.
The gas gauge could have a bad ground, bad gauge,or bad sending unit...my old one never worked that well either. Check your fuses as well. It sounds like a sending unit problem. Try the simple stuff first.
Blinker indicators could be blown bulbs in the cluster, bad flasher unit, bulbs not seated properly or grounds..bad bulb(s)
