Gauges
Shgnwgn79
15
47
Las Vegas, NV
So, as everyone knows I purchased my wagon about 4 months ago and ever since I got it the fuel gauge hasn't been accurate. Is there any way to test the gauges to in order to make sure they work before I go and drop the tank to put in a new fuel sending unit? Also wondering if there's a nicer set of gauges out there from a newer model that might also have overdrive settings on the shifting indicator since my '79 had a 700r4 swapped into it. Thanks for all the help!
You can test the sending unit and wiring at the connector by the rear bumper. Ground that pink wire and have somebody see if the gauge moves. Also remove the ground wire by the rear bumper and clean it, that connector commonly gets corroded.
