Phew, that's good. When setting up the gear pattern, leave the carrier preload at zero - there is no need to beat the poop out of your shims repeatedly. And I would not preload the carrier bearings more than .004-.005" on a GM Bolt. (.010" is alot)
0.004-0.005 total and not on each side from zero?
Correct.
pontiacgp - I think you're off by a decimal point or two on your backlash numbers.
OP - pontiacgp is spot on with that you should check your pattern in 3-4 locations around the ring gear - I had forgot to mention that and I also forgot mention that you should check your ring gear run out as well to confirm that it is .003" or less. If your ring gear runout is excessive it will wreak havoc trying to get the pattern and back lash set correctly. Usually the gear manufacturer supplies a recommended backlash setting - they are all not the same. .006-.010" is safe and I always err on the high side.
