Gen light always on
so no lights surging everything super bright and constant . im going to go over the board again later . i did notice a good amount of wear on some of the contacts that meet the wiring harness mounted in dash. Dont know if i really want to try and tin them up stupid plastic probably disintegrate .
Sounds like a bad diode in the diode trio in the alternator
https://gbodyforum.com/threads/gonna-need-some-help.67171/
Thnx for link. If this is what it is ill probably just pull the light . havent had a charging issue in 3 summers . always 14.2 14.3 at idle . i will check with rpm variation tomorrow to see if constant.
