Getting the F' Outta Dodge.
This was a fun exercise in shovel-nomics. It was moving pretty fast when I first opened it up. It is clear where I am going to need more permanent drainage solutions. We'll work on that over the next while.
PXL_20220404_230039992.MP.jpgPXL_20220404_230043043.jpgPXL_20220404_225936534.jpgPXL_20220404_225910882.jpg
This is not a crime heat map of Saskatoon... just pothole reporting.
Street sweeping starts this week... even if it might snow again tonight.
Dang, it flat there. Hard to get water to run across a table. What are all of your neighbor's doing for this, or do their yards/driveways look the same?
Those pics of the night sky are...............good.
Edit : what does the color difference mean on the 'pot hole heat map' indicate?
Green- It's a tooth clenching moment or worst case just a tire
Yellow- Moderate repair (shock, alignment, control arm)
Red- Your car has fallen into the earth's core, you need a new car
We are one of the lower properties so we might get a little runoff. But, there isn't a drainage problem except for where they put the shop, it needs a ditch or something to direct the water to lower ground. That's what I was figuring out yesterday. Our front drive is "dry", and not a soupy mess.
It doesn't help this was a "generational" winter and we are at the mercy of drifting snow. The skies are amazing.
Purple is the portal to another dimension.
Reactions: ssn696 and Rktpwrd
Started looking into "Getting the F' Outta Dodge Stage 2: The Contingency Plan." or more simply put alternative citizenships options.
First up; The USA.
EDIT: Who wants to be my family sponsor?
Reactions: Texas82GP
